Oven Wiring, Old House. - Appliances - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 08:26 PM   #1
Oven wiring, old house.
With a 40 amp circuit, 8/2 w/grd, I would like to know the correct wiring procedure for the red wire from the oven to the existing 1982 house wiring. .
Obviously blk/blk, wh/wh, grd/grd...
red connects to ___?
Many thanks
LF
Pluf2 is offline   Reply With Quote
Old 02-18-2012, 08:30 PM   #2
Rewards Points: 582
Many thanks
LF
what are the colors from oven...what are the colors from house?
Old 02-18-2012, 08:43 PM   #3
House - white, black, ground
oven - white, black, ground, red
I moved the oven and wiring to a new location in the kitchen and I spaced out taking note of what wire the red (oven wire) connected to on the house side.
Old 02-18-2012, 09:26 PM   #4
Rewards Points: 734
Hi Pluf,
You moved the wiring? Now you need to bring it up to the latest code. It was grandfathered, having only 3 wires, but 4 are now required. Existing circuits are not allowed to be altered.
Check with your electrical inspector to be sure.
You'll have to run an 8/3 w/grd for the oven.
Then the wiring is easy.
white - white
black - black
red - red
ground - green or bare conductor.
Hope it helps.
AandPDan is offline   Reply With Quote
Old 02-18-2012, 09:33 PM   #5
Yes. moved it @ 10 feet. I greatly appreciate the info. I will check as you mentioned.
Old 02-18-2012, 10:03 PM   #6
Rewards Points: 734
The reference is 250.140 under the National Electrical Code.
wiring portable generator into two house panels Rage Electrical 7 12-21-2010 05:40 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
New House Structured Wiring Setup for CATV gregsenne Electrical 13 02-19-2009 09:00 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 04:56 PM
