Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-31-2012, 07:27 PM   #1
oven temp fluctuates
our oven temperature fluctuates between 100 degrees of what it is set. Is there a piece we need to replace.
ckiesch is offline   Reply With Quote
Old 10-31-2012, 10:05 PM   #2
sdsester's Avatar
Is it gas or electric?
You know it is off that much because you put an oven thermometer in it or what method did you use to test the temperature?
Are the door gaskets intact and flexible or broken and brittle? Does the door close tightly?
sdsester is offline   Reply With Quote
Old 11-01-2012, 08:47 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
way more info needed here. Gas or electric, manual temp control or electronic, make and model?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 63 01-20-2013 07:55 PM
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 09:30 PM
Frigidare oven not keeping accurate temp Alleytom Appliances 1 12-20-2011 11:34 PM
Wall oven temp off by 40-50 degrees MovedTooMuch Appliances 4 12-02-2011 11:37 PM
New Kenmore Range 790.92604 wide fluctuation in oven temp tkolarik Appliances 5 09-10-2011 09:17 AM
