Oven Resets/shuts Off On Its Own - Appliances - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 10:46 PM   #1
Oven resets/shuts off on its own
Hello,
First post here.
I have a Kenmore electric oven that has started to randomly reset itself. It just shuts itself off while I'm using it. Sometimes it comes back on immediately with the clock flashing 88:88:88, sometimes it stays off until I operate one of the controls. There appears to be no pattern as to when it will act up. I could be using any element on the stove, or I could be using the oven.
The model number is 6817192. I don't know how old it is. The oven came with the house and I only moved in 3 months ago.
Any assistance/ideas/direction would be greatly appreciated.
dukewalsh is offline   Reply With Quote
Old 03-29-2009, 06:26 PM   #2
I tried to look that model up and didn’t seem to be a good model number. The problem sounds like the main board (if your range has one) but can’t say for sure because a problem like this can be hard to diagnose even if I were at your house looking at it. But I like a challenge every now and then.
Last edited by Scuba_Dave; 09-30-2010 at 12:48 PM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Old 03-29-2009, 09:34 PM   #3
Thanks for checking into it. I noticed from reading other posts that the model number didn't quite look like the others from Kenmore. I guess that might mean it's very old. Also, I'm in Canada, by the way. So maybe there is a different naming convention for models in Canada.
Thanks for the link. I'll be taking a look at it.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 10:48 AM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 06:05 PM
