Oven Range Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 11:28 AM   #1
Remove microwave range from bracket. Two large screws have been removed but the bracket will not release the microwave on one side as I believe it was installed on one wall stud.
lstamour is offline   Reply With Quote
Old 11-30-2011, 03:13 PM   #2
In the cabinet above the microwave, there should be two our three screws that go through the cabinet and into the top of the microwave. Remove those screws, then the microwave should tip forward and lift out. If this is not the case, please post the make and model if your microwave.
jfrotten is offline   Reply With Quote
replacing range with cooktop and oven diy-diy Electrical 2 10-10-2011 07:18 PM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 05:32 PM
replaceing a over the range microwave oven leeps Appliances 1 06-17-2010 11:46 PM
over the range microwave oven cmellinger Appliances 3 12-24-2009 12:36 PM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 03:47 AM
