Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-16-2010, 03:49 PM   #1
Oven only lights when I hit the gas valve!
Hi all, I have a maytag(or magic chef) 31001PAW. My tenant was using it to heat her apt (don't ask) and it quit working on her in the middle of the night. Now it won't light, the igniter gets hot and orange but no gas goes to the burner. But if I hit the gas valve it will light (sends gas) sometimes it will run for a while and sometimes it will run for just a bit then shut off again...either way it will not relight again unless I bang the gas valve again. Just want to make sure before I replace the valve that that is the problem not the ignigter. What do you think?
papashaq is offline   Reply With Quote
Old 01-18-2010, 10:45 PM   #2
Very little experience with gas here. Actually none with gas stoves. If you have an appliance parts store near you, someone should be able to tell you the most likely cause of the problem.
I will say this, it is not a good thing to heat with a stove with the door open, the controls have little chance of ever turning the heat off and something gets over worked. I think of it like a thermostat that has little chance of working as the heat needed to reset the switch never reaches the stat because the door is open and not sealed off. Imo, this is a dangerous situation. I'd rather use a space heater if extra heat is needed.
Old 01-21-2010, 10:24 PM   #3
as seen on tv
most modern ovens with hot surface ignitors use a current style valve. If your ignitor does not draw enough current the valve will not open,
qbert is offline   Reply With Quote
Old 01-22-2010, 09:24 AM   #4
I had a similar issue with my GE. The tenant did not try to heat the whole place but there was no ignition to the oven. The surface worked fine...I ended up replacing the valve for $100.00 and my time. Neighbor gave me some insight but I found step-by-step online(gas oven valve replacement)
Check Repair Dr or local appliance for part. Ignitors are alot more so I would start with the valve, esp if she's glowing.
Make sure to check the air intake in oven when you replace. You have to have balance of air intake and gas so as not to soot the oven...Great mess if not caught-sooty!! You can also find directions for this online...
Good luck. Worth doing yurself if you don't want to replace.
Han'D' is offline   Reply With Quote
Old 01-22-2010, 06:11 PM   #5
as seen on tv
use a amp meter and figure out what is really broke. Parts changing=$$$$
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
SCARY oven fire! Why did it burn? Beth777 Appliances 63 01-20-2013 07:55 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
