Oven Lights On Front Panel Not Working - Appliances - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 05:46 PM   #1
Oven lights on front panel not working
I have a Jenn-Air Model #JMW8527AA and the oven is heating correctly but the display on the front panels lights don't work. If you push the buttons they do work but you can't tell what you are pushing. If anyone has any idea's please let me know. I'm not sure how to take off the front cover to the oven it seems like you have to pry it off but I'm not sure and don't want to accidentally break it. Does anyone have a service manual for this oven? If anyone has any ideas on how to fix this please let me know. Any help would be much appreciated.
bsmith95610 is offline   Reply With Quote
Old 03-20-2011, 08:11 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
unfortunately you will need a whole new control, price is about $240.00. there is nothing you can replace back there to get the display to work
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-20-2011, 08:29 PM   #3
Do the controls normally snap in? If so do I just need to pry off the control then snap in the new one.
Old 03-20-2011, 09:12 PM   #4
#1 HAWKEYE FAN
no, that whole control panel will need to come off to get to the pcb. On that one I believe there will be 3 or 4 screws on the bottom side, remove them and pull forward. Unhook the wires and remove the pcb. Make sure you turn off power to stove first.
Tags
jenn-air , oven
Panel cleanup gdoucette Electrical 5 06-26-2010 03:01 PM
Ideal boiler 1-6 dial on front panel gonzo HVAC 1 06-01-2010 03:43 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Tip for ranges with a non working control panel. Jeekinz Appliances 1 03-11-2008 03:20 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
