Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-23-2010, 05:38 PM   #1
Oven Install and Replacement- Dacor $400
Hey friends, I could really use some help and advice on a home project.
I am replacing a single Dacor oven (ECS130SCH) with a NEW Single Dacor oven (D0130S). The first one died and is costing too much to fix.
The installer wanted $400 to swap them out. He charged $75 for a presite and told me the new one is 1/4" to tall and he can't do it. Hire a carpenter or buy a different brand.
I want to make it match so I am stuck on Dacor and I think I figured and easy way of moving the microwave up 1/4" and the cutting a 1/4" more to fit the oven.
Can someone look at my plans and see if they looks feasible?
1. I plan to lift the microwave 1/4" by inserting 1/4" plywood panel under the frame and reinstalling the outer aluminum panel. That will leave room for the new oven.
2. Width cutout is the exact same. But I plan to remove 1/4" of the wood for the top cutout with an electric saw carefully.
3. Insert new oven into new existing cutout and walah…save $400
What do you guys think?
This is the setup that I now have:
I need to move the microwave up 1/4" to have room for the new oven control panel that will be 1/4" higher:
So I will lift the microwave with 1/4" plywood and reinstall frame around it:
THAN cut out 1/4" of the top of the existing woven wood cabinet cutout. Here is my existing oven cutout requirements:
AND here are my new requirements. Only thing that has changed is the increase in height requirement for cutout and overall: and
SO, is this feasible or am I going to create a mess for myself?
CostcoMan is offline   Reply With Quote
Old 05-24-2010, 07:02 AM   #2
one thing about installations-you never know till you start..i looked on Dacor's site; old oven had cutout req of 27-1/2---new one calls for 27-5/8. that's only 1/8. i would think you could plane down top and bottom of cutout. before i did that though; i would measure everything on site. maybe the original cutout ran proud of spec's or new oven is not 'really'-'exactly' what they claim.[hard to believe but it happens].
Jacques is offline   Reply With Quote
Price quote for Marvin and Install. Opinions please. dignan99 General Discussion 5 06-10-2009 09:00 AM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 12:56 PM
Replacement Window - Nail Fin Question smoenra General Discussion 12 09-04-2008 11:19 AM
Install Fasco Inducer Model A242 morrelld97 HVAC 1 10-03-2007 08:40 PM
Install of Replacement HW Heater DIY In King George Plumbing 19 01-12-2007 08:49 AM
