Oven Handle Broken... How To Fix - Appliances - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 02:53 PM   #1
Rewards Points: 27
Oven handle broken (fixed) Plastic missing, what to fill in with?
I got the oven handle attached, but there is still a chunk of plastic missing at the bottom on the bottom... what would be the best way to go to fill it in and attempt to match it up with the oven?
Problem Solved: My oven handle is broken, some of the plastic broke on one side and the handle is only attached on one side... i tried krazy glue to reattach it and that didn't work... what can I do?
steve-19 is offline   Reply With Quote
Old 11-15-2010, 03:50 PM   #2
the Musigician
DangerMouse's Avatar
Short of replacing the door, you could try JB-Weld on it?
Use 5 minute setting type so you don't have to hold it for an hour....
DM
Old 11-15-2010, 06:33 PM   #3
40+yrs Paint Trades
I used fiberglass and laminating epoxy resin to repair an oven door handle. The handle was black, I added graphite powder to the resin and after sanding it was a perfect match.
I agree JB weld is some tough stuff.
hoz49 is offline   Reply With Quote
Old 11-17-2010, 03:49 AM   #4
Rewards Points: 372
JB Weld is good stuff. With any of the epoxy products, the longer the stuff takes to set up, the stronger it is.
fireguy is offline   Reply With Quote
Old 11-19-2010, 02:12 AM   #5
Rewards Points: 27
JB Weld worked like a charm. Now, what would you guys recommend to fill in the hole where the missing plastic is on the bottom? Think some kind of epoxy putty would work, followed by painting it black?
Old 11-19-2010, 06:30 AM   #6
40+yrs Paint Trades
The same JB Weld will work.
Old 11-19-2010, 09:57 AM   #7
Rewards Points: 27
It'a a deep hole, not just a scratch
Old 11-19-2010, 10:02 AM   #8
the Musigician
Can you access the other side? (unscrew door parts?) If so, put tape on the front nice and flat, then fill in JB Weld from the back side. When set, remove tape from front and paint the perfectly flat and flush filled spot. Po)
DM
Old 11-19-2010, 10:03 AM   #9
Rewards Points: 27
DM
Ah, great idea... thank you! I'll let you know how it turns out
Old 11-19-2010, 10:06 AM   #10
the Musigician
I'd mix up a big batch and reinforce the seam you already did on the back side as an extra measure while opened.
DM
Old 11-19-2010, 07:13 PM   #11
40+yrs Paint Trades
You can lay a piece of plastic (saran wrap) on top of JB Weld and it will cure smooth (if the plastic is smooth) .
Old 11-19-2010, 09:47 PM   #12
Rewards Points: 27
I think I am going to just order a replacement part... I am trying to find this is online for my range... I have a maytag CHE9800BCB... can anyone help me find this or let me know what this part is called ... thank you
Old 11-20-2010, 11:13 AM   #13
Trim,door-upper-#12001292.. ALL Brand Parts 800-252-7500. looks like it went NLA as of 6/10. could try E-Bay or some such.
Jacques is offline   Reply With Quote
Old 11-20-2010, 11:49 AM   #14
Rewards Points: 27
Thank you! The cheapest I found it for is $45.69
We are trying to sell this, not sure if it's worth investing $50 into it. I guess it will be a last resort. I'll try the JB Weld method first, to fill in the crack and go from there
Old 11-22-2010, 07:34 AM   #15
40+yrs Paint Trades
If it's a broken end (just visible at the top of the above picture) you can fabricate a patch using 6oz fiberglass and epoxy laminating resin. Make a backer form from cardboard, cover the CB with masking tape (the epoxy will stick to it otherwise) and lay up several layers of F/G and resin. Adding graphite powder to the resin at the end will match the black plastic.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Screen/Storm Door Handle Height Steven Z. General DIY Discussions 2 11-22-2009 05:38 PM
Single Handle to Tub/Shower is Broken gte304k Plumbing 2 10-24-2009 11:37 PM
Sillcock handle replacement jlbovo Landscaping & Lawn Care 7 08-04-2009 02:16 PM
Broken handle and dripping sound Sliding Man Plumbing 3 04-16-2009 03:03 AM
