-   -   Oven handle broken... how to fix (http://www.diychatroom.com/f47/oven-handle-broken-how-fix-86800/)
steve-19 11-15-2010 01:53 PM
Oven handle broken (fixed) Plastic missing, what to fill in with?
I got the oven handle attached, but there is still a chunk of plastic missing at the bottom on the bottom... what would be the best way to go to fill it in and attempt to match it up with the oven?
Problem Solved: My oven handle is broken, some of the plastic broke on one side and the handle is only attached on one side... i tried krazy glue to reattach it and that didn't work... what can I do?
http://i47.photobucket.com/albums/f1...e/IMAG0194.jpg
http://i47.photobucket.com/albums/f1...e/IMAG0193.jpg
DangerMouse 11-15-2010 02:50 PM
Short of replacing the door, you could try JB-Weld on it?
Use 5 minute setting type so you don't have to hold it for an hour....
DM
hoz49 11-15-2010 05:33 PM
I used fiberglass and laminating epoxy resin to repair an oven door handle. The handle was black, I added graphite powder to the resin and after sanding it was a perfect match.
I agree JB weld is some tough stuff.
fireguy 11-17-2010 02:49 AM
JB Weld is good stuff. With any of the epoxy products, the longer the stuff takes to set up, the stronger it is.
steve-19 11-19-2010 01:12 AM
JB Weld worked like a charm. Now, what would you guys recommend to fill in the hole where the missing plastic is on the bottom? Think some kind of epoxy putty would work, followed by painting it black?
hoz49 11-19-2010 05:30 AM
The same JB Weld will work.
steve-19 11-19-2010 08:57 AM
It'a a deep hole, not just a scratch
DangerMouse 11-19-2010 09:02 AM
Can you access the other side? (unscrew door parts?) If so, put tape on the front nice and flat, then fill in JB Weld from the back side. When set, remove tape from front and paint the perfectly flat and flush filled spot. Po)
DM
steve-19 11-19-2010 09:03 AM
DM
Ah, great idea... thank you! I'll let you know how it turns out
DangerMouse 11-19-2010 09:06 AM
I'd mix up a big batch and reinforce the seam you already did on the back side as an extra measure while opened.
DM
hoz49 11-19-2010 06:13 PM
You can lay a piece of plastic (saran wrap) on top of JB Weld and it will cure smooth (if the plastic is smooth) .
steve-19 11-19-2010 08:47 PM
http://i47.photobucket.com/albums/f1...e/IMAG0220.jpg
I think I am going to just order a replacement part... I am trying to find this is online for my range... I have a maytag CHE9800BCB... can anyone help me find this or let me know what this part is called ... thank you
Jacques 11-20-2010 10:13 AM
Trim,door-upper-#12001292.. ALL Brand Parts 800-252-7500. looks like it went NLA as of 6/10. could try E-Bay or some such.
steve-19 11-20-2010 10:49 AM
Thank you! The cheapest I found it for is $45.69
We are trying to sell this, not sure if it's worth investing $50 into it. I guess it will be a last resort. I'll try the JB Weld method first, to fill in the crack and go from there
hoz49 11-22-2010 06:34 AM
If it's a broken end (just visible at the top of the above picture) you can fabricate a patch using 6oz fiberglass and epoxy laminating resin. Make a backer form from cardboard, cover the CB with masking tape (the epoxy will stick to it otherwise) and lay up several layers of F/G and resin. Adding graphite powder to the resin at the end will match the black plastic.
