Oven Door Stuck - Appliances - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 12:10 PM   #1
Rewards Points: 27
Unhappy
Oven door stuck
My friend has a 15-20 year old Kennmore oven and someone used oven cleaner & somehow messed it up and now the door won't open. Latch moves but still won't open. Tried oven heat and settings but no results. Does anyone know how I can get the door open?
Determined is offline   Reply With Quote
Old 01-17-2012, 12:51 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Determined View Post
15-20 year old Kennmore oven ... used oven cleaner ... now the door won't open.
iirc.. if you lift the top burner section (as for cleaning)
there will be access to the lock mechanism.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Determined (01-18-2012)
Old 01-17-2012, 07:23 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
may have to access the lock mechanism from the rear panel, just depending on who made the stove
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-18-2012, 10:43 AM   #4
Rewards Points: 27
Thanks, will try.
Old 01-18-2012, 10:44 AM   #5
Rewards Points: 27
Thanks, will try.
Old 04-26-2012, 09:29 AM   #6
Rewards Points: 27
Talking
Thanks everyone. sorry to be so late. found out that the problem was nothing but two screws on the bottom of the door were not there someone somehow removed them, why? I'll never know. That caused the door to tilt and the lock would not move. A little pry up and to the side with the door did the trick. Anyway something like that. Very embarrsing.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 06:32 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Need recommendations for brand of new 24" single wall electric oven Stevoreno Appliances 5 05-09-2011 04:03 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 06:55 AM
