Hi there,
The heating element in my Peerless Premier Oven stopped working on Friday night. It had no heat.
Last night before I took it out to take it downtown today and get another one I thought I would make sure everything was connected tightly and give it another try. So I pulled out the connectors and made it sure it was connected properly and turned the oven back on. There was no heat and I was about to turn it off when suddenly it blew up inside the oven. The element itself did not blow up, but it blew up where the element connects to the connector. Sparks blew everywhere, a big puff of smoke, the electricity flickered off and back on in the house and it smelled a little like firecrackers.
It was really scary and we were really lucky both my son and I had literally just pulled our heads out of the oven when it blew up. If it had been seconds before our face would have been burnt.
Now in the hole where the connector and it's wire come into the oven there is another smaller hole that got burnt into the metal of the oven and it is all black like there was a fire in there.
So my question is this. Was this the result of the element going bad, or was something in the wiring and the connector causing the element to go bad? I've replaced elements several times in my life, but I don't know if it's safe to put a new element in or not.
I've had elements go bad before and usually there is a visible break in the element itself. But there is no break in it this time.
Would appreciate any words of wisdom if anyone has any.
Thank you.
Cynthia
