Out With Elec Cooktop, In With Gas - Appliances - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 11:14 AM   #1
Question
out with elec cooktop, in with gas
My first post!
I'm pretty handy, but my experience with elec is limited.
I believe I have 220 running to my electric cooktop now. When I install the gas one, I will need 110. Can I easily convert the 220 to 110 by simply replacing the circuit breaker in my box?
I imagine that one could not put 220 through skinny wires, but it seems like it ought to be safe to put 110 through thick wires. Any comments?
mathewmarie is offline   Reply With Quote
Old 11-08-2008, 12:24 PM   #2
typically 220v feed to rangetops is 3wire + gnd,,, for 110 powered sparkers, you only need 2wire + ground, probably 14 wire but i'm NOT an electrician,,, IF & when you want advice on concrete, i'll have a more inclusive answer
suggest you ask in the elec forum OR call an electrician for hookup in the distribution panel,,, in advance, you can run the new wire & attach the receptacle box under the range.
the previous hired remodeler in our house replaced same as you're intending,,, however, he just clipped the 220 line & left it hanging in the basement floor joists - never even turned off the breakers but he got paid & he's gone !
yesitsconcrete is offline   Reply With Quote
Old 11-08-2008, 01:34 PM   #3
thanks...
Old 11-08-2008, 02:21 PM   #4
Originally Posted by mathewmarie View Post
skinny wires,
thick wires
Copper wire diameter governs current carrying capacity, insulation thickness governs how much voltage it can insulate against (typically 600v for residential, it will be marked on the outer jacket).
Car battery cables and ignition cables are each about 1/4" dia. One carries 250A at 12v, the other carries 20kV at negligible current.
Old 11-08-2008, 03:19 PM   #5
what a know-it-all showoff yoy is don'cha just hate guys who actually KNOW something ? ? ?
Old 11-08-2008, 05:58 PM   #6
I agree; but, how can I fix this flaw in my character?
http://en.wikipedia.org/wiki/Character_flaw
Gas Cooktop Gap with Counter Mickey53 Appliances 8 07-03-2011 03:27 PM
Kitchen Remodel - Gap around CookTop Mickey53 Remodeling 4 11-08-2008 09:15 PM
need help with a new cooktop m_shel Electrical 9 02-08-2008 09:56 AM
Enlarging cooktop cutout in tile counter glenmorenee Remodeling 2 11-02-2007 10:13 PM
