Only One Ice Cube Slot Is Filling With Water In My Ice Maker. - Appliances - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 09:00 PM   #1
Only one ice cube slot is filling with water in my ice maker.
I replaced the inlet valve on my refrigerator and I used a hair dryer on the tube by the ice maker to make sure nothing was frozen and blocking my water flow. Why am I still only getting one cube of the try to fill with water?
Clroschen is offline   Reply With Quote
Old 08-27-2012, 10:39 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
what kind of valve do you have at the house water supply? What kind of pressure is at the refrig valve? Many times self tapping valves are used at the house plumbing, these corrode and plug up quickly cutting down on your water supply pressure.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-28-2012, 12:08 PM   #3
Rewards Points: 1,296
Ice makers are usually held in by a couple of screws into the side of the freezer wall. Unbolt it, pull it out and check it for blockage between the two sides
danpik is offline   Reply With Quote
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Softened water to fridge ice maker? droopdog7 Plumbing 0 05-29-2011 03:58 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
No water to dispenser or ice maker Shannicole Appliances 5 05-12-2008 07:17 PM
