-   -   Only one ice cube slot is filling with water in my ice maker. (http://www.diychatroom.com/f47/only-one-ice-cube-slot-filling-water-my-ice-maker-155057/)
Clroschen 08-27-2012 09:00 PM
I replaced the inlet valve on my refrigerator and I used a hair dryer on the tube by the ice maker to make sure nothing was frozen and blocking my water flow. Why am I still only getting one cube of the try to fill with water?
hardwareman 08-27-2012 10:39 PM
what kind of valve do you have at the house water supply? What kind of pressure is at the refrig valve? Many times self tapping valves are used at the house plumbing, these corrode and plug up quickly cutting down on your water supply pressure.
danpik 08-28-2012 12:08 PM
Ice makers are usually held in by a couple of screws into the side of the freezer wall. Unbolt it, pull it out and check it for blockage between the two sides
