Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-27-2010, 07:12 PM   #1
only 1/4 inch of frame & wall on each side of wall oven
I have an older home and need to replace the wall oven. Apparently ovens are larger than they used to be because they are too large for my opening. I found an oven that will barely fit leaving 1/4 inch of frame on the sides of the oven. The oven would be butted up next to sheetrock on one side , the other side is wood paneling .
Is it safe for the oven to be this close to the sheet rock? I know the wood paneling should be replaced with another material. Any suggestions about that?
tentativentexas is offline   Reply With Quote
Old 09-27-2010, 07:56 PM   #2
Civil Engineer
Read the specs on the particular oven you have in mind. I had a similar problem, I had an old 24 inch oven, hard to find them anymore, so we expanded the space and put in a 30 inch oven. As I recall, my oven required at least an inch of clearance all around, of course yours may be different.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
tentativentexas (09-27-2010)
Wall oven junction box sizing and placement benjamincall Electrical 6 06-10-2010 11:39 PM
Attaching fence post to side of retaining wall? Drew328i Landscaping & Lawn Care 5 06-01-2010 08:53 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Wall Oven Depth Surprise carusob Carpentry 2 06-29-2009 08:57 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
