One Of The Fourm Member Need Help With Dryer Issue - Appliances - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 12:57 AM   #1
" Euro " electrician
frenchelectrican's Avatar
one of the fourm member need help with dryer issue
I need a applanice guy here real quick as the moment I am searching the wiring diagram for this OP's dryer
Here the link to this subject so see how far it goes.
Help!!! My wife wants to buy a new washer and dryer
You can able see how far it been so far.
Merci.
Marc
Old 10-18-2009, 11:12 PM   #2
It seems to me that MickeyP is barking up the wrong tree. I am not saying that the thermostat is not the problem just that it would be the last thing I would check. Also the thermostat with the four wires is one of the ones that would cause this problem along with the one with two wires.
J. V. Put a parts breakdown to an electric dryer, does he know the thread is about a gas dryer?
Being that it is GE you will have a hard time finding a wiring diagram.
The first thing he needs to do is check for continuity across the igniter because it is the most likely thing to cause this. I don’t know the exact ohms reading but if it is not open it is more than likely ok. But of course if it is open he needs to replace it.
The next thing I would do is run the dryer with the drum out to view the gas valve. To do this he will have to keep the wires to the door switch intact. Also this model may have a belt tension switch, which will have to be pressed for the dryer to start.
What should happen is the igniter should glow red for a few seconds and then cut off and the flame should ignite.
If the igniter doesn’t glow then I would check the thermostats.
If the igniter does glow but doesn’t cut out after sometime (I don’t know the exact time 30 seconds maybe) I would replace the flame sensor (heat detector as some people call it).
If the igniter glows and cuts off more than likely the coils on the gas valve are bad.
If he is uncomfortable running the dryer with the drum out he can check the coils with an ohmmeter but it is unreliable because sometimes they check ok ohms wise but still don’t work. Again I don’t know the exact ohms right off. But he can’t check the flame sensor.
Hope this helps!!
All of this and more is on this page
Last edited by Scuba_Dave; 09-30-2010 at 12:33 PM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Old 10-18-2009, 11:18 PM   #3
Merci { Thanks } that will help the OP with the details
Merci.
Marc
Old 10-19-2009, 12:43 AM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
dang, this is a simple problem:
pay the gas bill.
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Dryer Recepticle Issue.. LOST! Lost in Washington Electrical 3 12-22-2008 11:40 AM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
