Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-12-2012, 08:33 PM   #1
Is it ok to use this connector in a toaster oven?
My cuisinart toaster over/broiler's top elements stopped working so I decided to open her up just to see if anything was blatantly obvious. One of the wires going to the element melted/burnt off. All I had to reconnect it was the male connectors above, except the insulation is blue. I cut off the burnt part of the wire, stripped it, and crimped it in the above connector. I then bent the metal from the element and the metal from the connector so that they would interlock and then crimped them together. Any issue with the amount of electricity or even the heat from the toaster with the insulation on the connector? I tried it out and it's working fine, but thought id ask here before using it too much. Thanks for any help.
mikegp is offline   Reply With Quote
Old 11-12-2012, 09:16 PM   #2
You need to check the rating plate on your unit for amperage and then check what amperage those connectors are rated for. If they can't handle the load they'll melt soon enough.
MarkusAIC is offline   Reply With Quote
Old 11-12-2012, 09:36 PM   #3
They don't say. Just says 16-14 gauge.
Old 11-12-2012, 10:15 PM   #4
yes.......... but i wouldn't..... if you do take the insulation off those therminals other wise the will melt when you turn the oven on. AGAIN I WOULDN'T DO THIS. GO TO A SECOND HAND STORE AND GET A NEW ONE OR GO TO WALMART.
redman88 is offline   Reply With Quote
Old 11-12-2012, 10:19 PM   #5
I used it through 4 full toasting cycles and put it on broil 450 degrees for 10 minutes. No sign of melting, smoke, or smell.
Old 11-13-2012, 12:05 AM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
if you made a good solid crimp connection you'll be ok.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-13-2012, 12:10 AM   #7
Should be fine if a solid crimp was done.
We typically use a high temp stainless connector when regular connections are unsuitable
Protocol. is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 63 01-20-2013 07:55 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Need recommendations for brand of new 24" single wall electric oven Stevoreno Appliances 5 05-09-2011 04:03 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 06:55 AM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
