Oil Fumes - Appliances - DIY Chatroom Home Improvement Forum
Old 12-16-2008, 08:44 AM   #1
oil fumes
i have blown out the lines replaced the nozzle and filters on my ruud furnace but keep getting oil fumes when furnace comes on
regalrat is offline   Reply With Quote
Old 01-13-2009, 05:51 PM   #2
oil fumes
Not really answers but some things to check before calling a repairman.
Do the fumes go away when the circulation blower starts?
I once thought we had a crack in the heat exchanger but upon removing the access to the inspection / cleanout for the exchanger I had found the repair man had not replaced a broken gasket.
Are there any obstructions in the flue pipe or chimney?
How full is you fuel tank?
On an older furnace we use to have it would stink when nearing the bottom of the tank. I don't notice this on the newer furnace.
tagra123 is offline   Reply With Quote
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 25 12-04-2014 06:05 PM
Help removing carpet padding! bradleybunch Flooring 32 10-14-2012 09:52 AM
Rattlesnakes!! Cyndi Pest Control 36 12-14-2008 01:50 PM
Removing old Liquid Nails melkisadek Building & Construction 5 01-12-2008 03:21 PM
Sick from fumes from new furnace lsheldon HVAC 5 01-03-2007 12:16 AM
