Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-02-2009, 01:29 PM   #1
Default oil fired furnace issues
I woke up this morning to a 62 degree home. NOT COMFY!
I went down to my furnace and pushed the reset button. It acted like it was going to fire up and then it quit. I kept going down every 1/2 hour or so to try this again. I did this about 5 or 6 times.
A few moments ago it actually fired up. Then it produced white smoke from the little door you can open to make sure it fires up and the exhaust pipe where it goes to the chimney. Then it shut off.
PLEASE tell me my furnace is not toast. I can not afford to replace it right now.
mrsbud is offline   Reply With Quote
Old 11-03-2009, 08:41 PM   #2
Default Oil Furnace
You really need a pro,for this one.Every time you hit reset button,you're dumping oil into combustion chamber.This can get pretty nasty,and dangerous. My $.02 worth
d scott is offline   Reply With Quote
Old 11-04-2009, 06:29 AM   #3
not necessarily toast. Good be several issues. Clogged jet, faulty pump, electrode gap set wrong, controller starting to go, reset failing or flame detector is dirty. all can be fixed. If it fails while you are servicing it you may find the problem. But intermittent failures will be troublesome to get resolved.
Bob Mariani is online now   Reply With Quote
More On This Topic
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
More Ways to Glaze Pottery
More Ways to Glaze Pottery by Expert Village
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. Now our firing is completed, after 1100 degree Cecilius temperature we keep the furnace 1 day for cooling. Now I'm opening the furnace see this is the door and our cups... Read More »
How to Bake Pottery
How to Bake Pottery by Expert Village
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. Our bisquting product is ready, I baked our items for 8 hours at 850 degrees Cecilius and left for one day to let the furnace go to normal temperature. Now I'm opening... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
A real orchid aficionado that has wide collection of plants knows that they have to have a variety of temperature zones that they have to grow their plants at. And in this greenhouse range which I've had for the last few years, I grow in three... Read More »
Oil fired furnace replacement ideas Davidb6 HVAC 10 02-05-2009 10:34 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
carrier furnace issues sbroways HVAC 2 10-15-2007 10:30 PM
Putting a new Motor in a Carrier Furnace... Wiring issues cbrent HVAC 3 10-08-2007 08:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
