Oil Drip From Refrigerator Door - Appliances - DIY Chatroom Home Improvement Forum
Old 12-15-2010, 07:35 AM   #1
Oil drip from refrigerator door
I have a strange oil drip from the corner of my refrig door. At first I thought it was coming from a spill inside but its not. It's like a clear oil and makes a small puddle each day. I didn't think there would be any oil used inside the door unless it might be used as an insulation of some type, but that doesn't seem logical. Any ideas what this could be and how to fix it?
Alan Lenk is offline   Reply With Quote
Old 12-15-2010, 08:29 AM   #2
the Musigician
DangerMouse's Avatar
Oil? That IS weird..... I'd take a frying pan, warm it up (not red-hot!) on the stove a little, then capture a drop and see if it evaporates or not. Does it have any smell?
DM
Old 12-18-2010, 02:26 PM   #3
DM
Your compressor is leaking
Sellwithnic is offline   Reply With Quote
Old 12-21-2010, 07:11 PM   #4
Rewards Points: 1,514
Are you sure the oil is coming from the door as opposed to leaking out of the body of the refrigerator and down the hinge and along the underside of the door?
Bottle of cooking oil in the door rack is leaking?
Old 12-22-2010, 05:14 AM   #5
Seasoned DIYer
Rewards Points: 150
There is a high side loop going along the freezer door frame to prevent the door from freezing on. I'm not sure if its done for the refrigerator part. If it springs a leak, the refrigerant along with oil will come out, although it will stop working if its leaking.
If still cools, its coming from something else.
HVAC_NW is offline   Reply With Quote
need advice pinning down existing drip cap balaway General DIY Discussions 2 05-07-2009 05:15 PM
drip cap question marlinpuppy Building & Construction 1 03-17-2009 11:10 PM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 08:14 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Furnace Drip!??! acawley22 HVAC 1 01-10-2007 08:36 PM
