Odor Coming From Dishwasher - Appliances - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 01:43 PM   #1
odor coming from dishwasher
A few weeks ago we had a new garbage disposal installed. Recently an odor has been coming from the diswasher. I can see where the hose from the dishwasher is hooked to the disposal, but could the installer of the disposal forgot to remove the knock out plug? The dishwasher operates, but seems to be laboring and much more noisy than before.
joseph thomas is offline   Reply With Quote
Old 01-14-2012, 01:45 PM   #2
Rewards Points: 14,302
Call him back and ask.
Old 01-14-2012, 07:53 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
if the dishwasher drains then he removed the knock out, most likely he did not loop the dishwasher drain hose above the disposal outlet. You are probably getting nasty discharge water from the disposal backing into your dishwasher
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
del schisler (01-18-2012)
Old 01-15-2012, 10:33 AM   #4
Hardwareman is right... The installer probably threw away the zip tie that came with the dishwasher and neglected to secure the drain line above the disposal.
jfrotten is offline   Reply With Quote
The Following User Says Thank You to jfrotten For This Useful Post:
Old 01-18-2012, 12:51 PM   #5
Agree with the above. If the knockout plug was still in there, you would be swimming in your house. The smell could a number of reasons, the most likely being it's not draining right. Sometimes the garbage disposal is the issue. This will be a bit of a pain but try running it when the backflow comes out of the dishwasher and see if it helps the draining.
A few lemons in the disposal can't hurt either.
Phillies48 is offline   Reply With Quote
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 12:56 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
