Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-09-2012, 07:24 AM   #1
Is this normal?
Hi,
I found a cut on the side of the HVAC unit (approximately 6inX6in), where the plenum is. Hot air is blowing through it and obviously it was done by the original installer (I rent this apt.) Is this normal? What is it done for? Should I be concerned about it? Does it endanger my health in any way? Thank you in advance for your help.
nnorby1 is offline   Reply With Quote
Old 02-09-2012, 07:28 AM   #2
Is this normal?
How about a picture so we can see what your talking about.
Unless it's a hole in the freon line, or condinsate line there is no danger.
If it's just a hole in the duct work just put a patch of foil duct tape over the hole and forget about it.
Old 02-09-2012, 07:49 AM   #3
Is this normal?
I'm sorry for the delay.Here are the pics.Thank you.
http://imageshack.us/photo/my-images...209063723.jpg/
http://imageshack.us/photo/my-images...209063742.jpg/
Old 02-09-2012, 07:58 AM   #4
Is this normal?
Old 02-09-2012, 01:11 PM   #5
Is this normal?
Go to your local hardware store and get the heat resistant tape ( will ne shinny aluminum color) and go to town taping up hole cover about 1'' - 2'' excess around area you are covering .
Ps make sure furnace is OFF while you prefrom this task .
acestarservices is offline   Reply With Quote
Old 02-09-2012, 01:17 PM   #6
Is this normal?
Thank you kindly.
I appreciate your help.
Sliding Glass door Issue - Where to find a slightly smaller than 'normal' door LordX Building & Construction 1 01-18-2012 02:49 PM
Is This Normal? (frost in new fridge) Old Lady Appliances 23 08-16-2011 10:59 AM
Overflow drain stained black, normal? Drywallhelp Plumbing 5 08-14-2011 08:48 PM
Inside of the deck a little moist, is it normal xusword Roofing 8 02-07-2011 11:32 PM
coolant indicater staying cooler than normal raptor99 Automotive Repairs 5 02-16-2010 04:19 AM
