Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-04-2011, 07:00 PM   #1
nordyne gas furnace
the igniter glows gas valve click but don't seem to be any gas coming out .I wiggled wires on valve @ pushed in on black plastic where wires hook it then lit but when turns off won't relite.
armyvet68 is offline   Reply With Quote
Old 11-21-2011, 09:16 AM   #2
Milwaukeetool's Avatar
nordyne gas furnace
try cleaning the flame sensor with a scotch btire pad
Milwaukeetool is offline   Reply With Quote
Old 11-26-2011, 02:40 PM   #3
nordyne gas furnace
if that makes it work everytime sounds like you need a new valve (loose internal connection)
kennzz05 is offline   Reply With Quote
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
