None-stop Oven Igniter - Appliances - DIY Chatroom Home Improvement Forum
Old 07-28-2015, 11:49 AM   #1
Property Mgt/Maint
Rewards Points: 1,018
None-stop oven igniter
just hooked up a older model stove by "True-Test" ? (never heard of this brand).
Top burners all function normally, the oven burner ignites but the igniter continues its clicking the entire time the oven is in use. The previous owner says "its always done that and it is too costly to fix". I haven't checked under the hood yet, but wouldn't this be a simple flame sensor problem?
Maybe a $25 item?
Yodaman is online now   Reply With Quote
Old 07-28-2015, 12:31 PM   #2
Rewards Points: 83
Could be a flame sensor. Could also be a damaged ground connection. I would ensure the flame sensor is clean and that all grounding connections are proper. Failing that. The ignition module may be required.
Protocol. is offline   Reply With Quote
The Following User Says Thank You to Protocol. For This Useful Post:
Yodaman (07-28-2015)
Old 07-28-2015, 03:17 PM   #3
Property Mgt/Maint
Is a separate equipment ground required? Currently there is only the ground from the electrical outlet.
Old 07-28-2015, 05:41 PM   #4
Rewards Points: 83
Shouldnt require seperate grounding. On some ovens the burners/ignition controls are grounded. I would ensure that those are secured as well as any equipment grounds inside the unit.
Old 07-31-2015, 04:00 PM   #5
Rewards Points: 876
I have a Kenmore gas counter-top stove and it has always had an intermittent problem with the igniters. Sometimes - especially if there is the slightest breeze while the stove is on - the igniters on all burners click constantly.
I have found that they will also click constantly if any of them is wet.
I had always thought the only time power should be applied to the igniter circuit is when you push the knob in to light, but that is not the case with my stove.
If you can find the wiring diagram (usually located under a panel that doesn't get hot), it should be a help.
Ultrarunner2017 is offline   Reply With Quote
The Following User Says Thank You to Ultrarunner2017 For This Useful Post:
Yodaman (07-31-2015)
Kitchen options-relocating dishwasher or oven jaybroncos30 Kitchen & Bath Remodeling 12 01-15-2013 02:33 PM
oven stuck in broil gcan Appliances 2 12-30-2012 10:42 PM
Whirlpool oven igniter JIM FLYNN Electrical 3 11-16-2012 07:19 AM
Wall Oven blocked by Electrical heyjoe91 Electrical 6 09-13-2012 12:58 AM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-02-2011 11:09 PM
