Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-12-2007, 10:14 PM   #1
noisy washer agitator
My Whirlpool Design 2000 top-loading washer (bought in 1987!) has started making a loud noise. The noise is in rhythm with the agitator. It only does it during the wash cycle when the agitator is moving back and forth. While I realize I have received my money's worth out of this washer after 20 years, if this is something fixable, I'm willing to give it a try. Thanks in advance for any suggestions.
bucksone is offline   Reply With Quote
Old 08-12-2007, 10:34 PM   #2
Agent 000
SecretSquirrel's Avatar
This is more of a story than DIY advice. I had a similar issue with a 15 year old Sears Kenmore washer except my spin cycle quit working. I'm a DIY type of guy right? Well I started dismantling the washer to find the source of the problem and uncovered the remnants of some sort of nylon gear or bushing. I whipped out my service manual and after studying the possible components that could have contributed to the meltdown and then looking at the washer transmission, not to mention the looming pile of laundry, the next thing I did was call a service center to see what a "hypothetical" repair would cost. After hearing that bad news and looking at the prospect of a real PITA and time consuming repair I decided to save what little hair I have left on my head and take the washer to the dump and replace it with a new one. A wise man chooses the battles he is capable of winning.
Individual results may vary.
SecretSquirrel is offline   Reply With Quote
Old 08-13-2007, 11:06 AM   #3
Custom Cabinet Maker
Buck: Padre Espritum Sanctum
Take the wife out to lunch and a shopping trip
skymaster is offline   Reply With Quote
Old 08-16-2007, 09:47 PM   #4
What type of noise?
Watch it while it is in wash mode and see if the tub is going from side to side or wobbling. If it is, raise the top and look in the corners for rubber dampers going from the tub to the washer itself. One or more may be broken if it has them. If it has springs on the bottom that serve basically the same purpose, check them. These will be heavy springs if it has them. Be careful when installing or remmoving. Do you know if it is direct drive or belt driven? If direct drive, definitely check the coupler. Not really sure how far back the direct drives go. Just some suggestions without being there to actually see it.
Old 01-04-2008, 02:18 PM   #5
What is the model number of the washer?
The model number should be on a tag in the opening of the washer where you put the clothes in.
If the agitator is a duel action type it has what are call dog in it and a cam that could be making the noise.
girltech is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
Is it possible I have a 220 running to my dish washer? aljanney Electrical 25 02-15-2007 11:08 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
noisy tap (really noisy!!) - help please Nikki Plumbing 2 04-23-2006 09:56 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
