Noisy Vacuum - Appliances - DIY Chatroom Home Improvement Forum
Old 06-03-2014, 10:41 AM   #1
Rewards Points: 137
Noisy vacuum
I have a Hoover Windtunnel series vacuum cleaner model UH70240 bought last August. In the last few weeks it has become extremely loud when used. It still cleans but you almost need earplugs to use it. The dirt cup is emptied, the filters are clean, the brushroll is clean, and the belt looks fine. Any idea what may be causing this?
Also, today, the cup at the bottom that holds the hepa filter comes open when the vacuum is turned on. I'm thinking this might be unrelated as it just started today, but I don't know why this is happening.
As usual, any suggestions will be appreciated.
bucksone is offline   Reply With Quote
Old 06-03-2014, 01:38 PM   #2
PoleCat's Avatar
Rewards Points: 1,646
The impeller blade may have a crack in it. They are air raid siren loud when they get cracked.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Cleaning a vacuum cleaner... Gerry_D Appliances 3 04-14-2014 12:33 AM
Water Heater Vacuum Breaker Needed??? Trgo Plumbing 1 10-21-2012 06:34 PM
Central vacuum issue omgwtf Appliances 6 10-14-2012 08:05 AM
Outside Faucet Vacuum Breaker - defeat or remove? tjtv Landscaping & Lawn Care 2 09-27-2011 05:49 PM
Inducer Vacuum Problem RobertCan HVAC 21 12-22-2009 03:20 PM
