Noise From The Faucet That Supplies Water To The Refrigerator Ice Maker. - Appliances - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 05:41 AM   #1
Noise from the faucet that supplies water to the refrigerator ice maker.
There is a constant noise coming from the faucet where the water flows to the icemaker. I have turned the faucet off & the noise continues; a high pitched noise. Is this air in the line or what? The refrigerator has been hooked up for 4 years, and this is a new noise. It is not the refrigerator making the noise; it is clearly from the faucet in the wall. No water leaks noted. HUH?
lwasserman is offline   Reply With Quote
Old 07-19-2011, 10:36 PM   #2
Rewards Points: 123
Maybe the noise is being generated from somewhere else in your plumbing system and you happen to hear it from said faucet, something like a leaky toilet tank. I might try to turn off the main supply valve and de-pressurize the system and give it a listen to start somewhere.
readar is offline   Reply With Quote
Low water pressure in kitchen faucet after replacing water heater SusanonDaffodil Plumbing 8 01-27-2011 01:28 PM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
