No Water Is Flowing In To Make Ice - Appliances - DIY Chatroom Home Improvement Forum
Old 07-29-2011, 12:50 AM   #1
no water is flowing in to make ice
If the water is flowing to the water dispenser shouldnt it be flowing to the icemaker?
sfraser is offline   Reply With Quote
Old 07-29-2011, 08:55 AM   #2
Remodeler
Rewards Points: 330
Not necessarily, there are two separate valves. One for the water through the door, the other to the ice maker. One solenoid or valve can stop working and the other can still work fine.
The tube that carries water through the back of the freezer compartment can also freeze solid and not allow water to get into the ice maker. The tube steps up to a larger size inside the freezer cabinet and it is angled downward so it empties after filling to avoid freezing, but it still can happen.
iamrfixit is offline   Reply With Quote
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Condensation line flowing lots of water (pics inside) Volleyballer[G8 HVAC 12 07-26-2010 12:46 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
