No Water On Door Or Ice Maker - Appliances - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 08:38 AM   #1
No water on door or Ice maker
I have a Whirlpool Refrigerator. Model number ED5VHGXMB00
After I repair the drum on the ice maker bin yesterday and changed the filter I am not getting any water out of the door and the ice maker is not making ice. I can hear the switch from the door when I try to get water but nothing comes out.
Thanks for any help.
sagahafer is offline   Reply With Quote
Old 11-26-2008, 09:11 AM   #2
Did you try removing the filter, then see if you get water at the door ?
Lew_B is offline   Reply With Quote
Old 11-26-2008, 09:35 AM   #3
No I thought you had to have the filter in for it to work. I will try it.
Ok that did not work. I also tried to putting the old filter back in that did not work
Old 11-27-2008, 09:18 PM   #4
My sound silly, but you have to start from the begining. Did someone lock the control panel?? Is there water going to the frig? next: do you hear a faint buzz from the valve when you depress the switch??
sv9779 is offline   Reply With Quote
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
No water to dispenser or ice maker Shannicole Appliances 5 05-12-2008 08:17 PM
HELP - No Water to Ice Maker noice Appliances 13 07-17-2007 10:41 AM
