No Spin Cycle - Kenmore - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 10:03 AM   #16
OK - I made some videos, not of the greatest quality, but hopefully you can see what is going on here
1. This just shows a general lay of the land, the washer is not running:
http://www.youtube.com/watch?v=bzXMo...ature=youtu.be
2. This shows the washer during the agitation phase (where it seems to be operating normally)
http://www.youtube.com/watch?v=wKlGk...ature=youtu.be
3. And this where it gets weird. This is the spin cycle, but not is actually spun down with no whining noises, etc. Now, there were no clothes in there, and also not much water, so that could have something to do with it. But, it wouldn't even spin before (although it would drain)
http://www.youtube.com/watch?v=kww2Z...ature=youtu.be
Additionally, the drum does spin freely and the belt tension does seem to be somewhat snug, though I'm not sure what it's actually supposed to feel like.
Thanks again for all of the help so far!!
sobro is offline   Reply With Quote
Old 06-27-2013, 10:24 AM   #17
Rewards Points: 44
Hmmm. It could be the belt is worn out or its the spin bearing. I don't want to steer you in the wrong direction and start swapping parts for no reason.
To me, since the drum does spin with no load I think the belt is stretched and is slipping under load--burning smell. It's the cheaper of the parts to replace. After that, it might be the spin bearing or the transmission.
Dan
djlandkpl is online now   Reply With Quote
Old 06-27-2013, 12:38 PM   #18
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Frigidaire built washer, very high maintenance unit. If the belt is turning during spin the transmission should turn to spin tub. Burnt rubber smell means belt burning, first step would be to replace the belt and the belt tightener.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
djlandkpl (06-27-2013)
Old 06-27-2013, 04:28 PM   #19
Well, it gives me a place to start. I am going to try with the belt and the bearing first. If that doesn't work, then I'll probably have to get someone with more experience than myself.
Thanks again for all of the input - I will keep you updated.
Old 07-09-2013, 07:55 AM   #20
Update: I replaced the old belt. It was starting to shred and was becoming quite brittle. Also, for some reason, the rubber was leaving my hands completely black whenever I touched it! Hopefully this doesn't happen with the replacement!
I did not replace the spin bearing yet as I am waiting to see how this repair goes
Thanks again for all of the help!!!
The Following User Says Thank You to sobro For This Useful Post:
djlandkpl (07-09-2013)
Tags
kenmore , w/d combo , won't spin
loud washer knocking/banging noise during spin cycle NABRIL Appliances 0 01-14-2013 01:51 PM
Kenmore Washer stops working at drain point in cycle Eagle One Appliances 19 11-19-2012 12:44 PM
GE Washer vibrates like crazy in Spin Cycle medicpg Appliances 12 04-19-2010 11:36 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 01:10 PM
