No Spin Cycle - Kenmore - Appliances - DIY Chatroom Home Improvement Forum
Old 06-24-2013, 11:26 PM   #1
I have a stacked Kenmore w/d combo Model #41793812200. It fills up with water and agitates just fine, but when it is time to spin down, that's when the problems begin.
The pump pulls out the water, but the tub does not spin. What's more, I have heard a high-pitched whining during this part of the cycle (and yes, my wife was out of the house, so that is eliminated). Additionally, I noticed a slight smell of burnt rubber.
Anyone have any ideas on this one?
Thanks!
sobro is offline   Reply With Quote
Old 06-25-2013, 08:26 AM   #2
Rewards Points: 13,300
The model # you entered is wrong, please try again.
Your missing the decimal points.
Old 06-25-2013, 11:12 AM   #3
Busted!
Here it is: 417.93812200
thanks
Old 06-26-2013, 03:57 PM   #4
Anybody have any thoughts on this? My laundry is starting to pile up...
Old 06-26-2013, 04:20 PM   #5
Rewards Points: 12
2 thoughts.
1) There's a switch on the lid to tell the machine that it's closed before it will spin. The switch might not be engaging.
2) The drive belt is broken or bad. I'm leaning towards this being the issue since you smell rubber and hear squealing during the spin cycle.
Dan
djlandkpl is online now   Reply With Quote
Old 06-26-2013, 04:49 PM   #6
Ok - thanks for the ideas.
I do have another question, though: If the belt were bad, then would the washer still be able to agitate? I watched it work and it didn't seem to have any issues during that part of the cycle...
Thanks,
Old 06-26-2013, 04:54 PM   #7
Rewards Points: 6,652
Originally Posted by djlandkpl
2 thoughts.
There would not be a belt on newer units. They are all direct drive, with a transmission and a coupling.
If I had to guess, the transmission is shot, and with that the coupler and rubber pieces will also need to be replaced.
The parts can be found on http://www.repairclinic.com and have them in two to three days. Total time to fix would be around two hours, four if you are really slow.
I have done it in 45 minutes on a stand alone unit by myself.
Old 06-26-2013, 04:55 PM   #8
Rewards Points: 12
Thanks,
Not sure. The agitator could be directly connected to the motor. The easiest way to know is to open it up and see.
Dan
Old 06-26-2013, 04:57 PM   #9
Rewards Points: 12
Repairclinic has his model with a belt which is why I suggested it.
Dan
Old 06-26-2013, 05:29 PM   #10
Thank you. I was on my phone replying, so did not go to repairclinic. If the belt was shot, the unit would do nothing at all.
So next guess would be still the transmission. It would allow for agitating, but if shot, would not go into spin cycle.
Easy way to find out is to move the unit and look for oil or greese spot on the floor.
Old 06-26-2013, 06:04 PM   #11
I have had the cover off of the lower unit, and there is definitely a belt. The tension felt reasonable (ie not too loose).
I didn't notice an oil spot, though. Can the transmission go out and not leave any oil on the floor?
Old 06-26-2013, 06:18 PM   #12
Rewards Points: 12
Try running it thru the spin cycle with the cover off an see if the belt is slipping.
Dan
Old 06-26-2013, 08:09 PM   #13
I will double check it tonight. If I remember correctly, I did run the spin cycle the other night while the cover was off and the belt didn't even attempt to move. If that's the case - transmission?
will report back...
Old 06-26-2013, 09:47 PM   #14
Motor, transmission, coupling, belt would be the three suspects. Otherwise, corrosion at the harness between the two units also could be causing the issue.
Just have to put it all out on the table since not there to see what ia going on.
If you can get a really good video while trying to get it running, helps us if you cannot figure out from the three what is going on.
Old 06-27-2013, 08:53 AM   #15
Rewards Points: 12
I looked at searspartsdirect and they have assembly diagrams. From what I can tell, the transmission mounts directly to the motor and the transmission drives the agitator. The drive belt is below the motor and spins the drum.
With the machine off, are you able to spin the tub?
Are you able to move the belt with it off?
The washer has a part called a spin bearing. It's possible that it has failed.
Dan
Tags
kenmore , w/d combo , won't spin
loud washer knocking/banging noise during spin cycle NABRIL Appliances 0 01-14-2013 02:51 PM
Kenmore Washer stops working at drain point in cycle Eagle One Appliances 19 11-19-2012 01:44 PM
GE Washer vibrates like crazy in Spin Cycle medicpg Appliances 12 04-19-2010 12:36 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 05:03 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 02:10 PM
