No Spin - Appliances - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 08:19 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
No spin
I have a Whirlpool cabrio about 2 years old (no agitater),,, that won't spin.
Before I take it apart ,,,any suggestions or should I just call Sears and take out the checkbook??
Barry
Barry J is offline   Reply With Quote
Old 02-18-2013, 08:25 AM   #2
Rewards Points: 214
Is it plugged in? Is it receiving power?
rosem637 is offline   Reply With Quote
Old 02-18-2013, 08:33 AM   #3
Rewards Points: 13,260
Check here for info.
http://www.repairclinic.com/RepairHe...ne-Repair-Help
Going to need your model #.
Old 02-18-2013, 08:51 AM   #4
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
The repairs seem pretty simple, but, how do i tell which part or parts is my cause for the no spin....and thanks, but yes it is revceiving power.
thanks
Barry
Old 02-18-2013, 08:55 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
no spin could be a lot of things. Cabrio should give you an error code if it is not spinning.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-18-2013, 09:16 AM   #6
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I flipped it over, took it apart, and the belt was off, I put it bAck on, and it spins.
But, why did it slip off???
Is there a way to prevent that?
And where would the "code" come up??
I have a Cabrio model # WTW5500XW1
Don't know if it has the "code" option
Barry
Old 02-18-2013, 09:39 AM   #7
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
It's working, but right now it seems to be making that same strange sound it made before it stopped working.
I noticed that the belt shield was cracked...is that causing the belt to come off???
It sounds like there is something else going on.
I know these machines make wierd noises to begin with, but this one is different.
any suggestions???
It's in the wash cycle and it's making noise like something is slipping
Could it be the belt already, not that old of a machine.
Or is there a way to tighten the tension
Old 02-18-2013, 09:58 AM   #8
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
It spins with normal noise and action, it's when it seems to be in the "wash" mode, that it makes the noise, when it makes the back and forth motion seems it be the problem, like I said, one direction spin..no noise
Old 02-18-2013, 03:14 PM   #9
#1 HAWKEYE FAN
you will need a new cam assy. part# W10315818 about $35.00. When you put the belt back on you put the belt around the motor and the pulley for the cam, that is the piece you replace. Common problem.
Old 02-18-2013, 04:31 PM   #10
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
How about a loose belt?? Would that be the prob??
Or definite it's the cam?
Barry
Old 02-19-2013, 08:54 AM   #11
#1 HAWKEYE FAN
definite cam
Old 02-19-2013, 09:46 AM   #12
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I looked on "repair clinic" website, and it shows a couple of pieces with the cam for $36.55,,of course that is out of stock, but I go onto the Sears direct part website and the cam is only $10.61 in stock. But both have the #W10315818 part number. Any suggestions
Barry
Old 02-19-2013, 06:35 PM   #13
#1 HAWKEYE FAN
order it from Sears, but that is way to cheap. Not sure if that is a misprint or what so snatch it up before they catch it. I can't even buy that from my wholesaler that cheap.
Old 02-20-2013, 02:03 PM   #14
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I actually went theu "appliance parts pros" for the whole kit for $21
Barry
Old 02-27-2013, 06:10 PM   #15
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Changed the cam, the belt and the plastic shield for under $65, working like a charm
Thanks for the help
Barry
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 05:23 AM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 01:39 AM
Washing Machine Not Reaching Max Spin Shelley Appliances 2 11-30-2008 10:12 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 05:03 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 02:10 PM
