Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-06-2010, 12:47 AM   #1
Wire Chewer
Red Squirrel's Avatar
No more emptying the dehumidifier bucket!
So I decided to get creative, and added a tap on my dehumidifier bucket. I can now attach a hose to it, and let it drain in the sump pit. The silicone caulk is still drying but I can't wait to give this a test tomorrow.
If you wonder why I put it sideways, it's to compensate for the hose bend radius.
Old 08-06-2010, 12:57 AM   #2
Electrician
Proby's Avatar
If you dump it into your sump pit, won't a lot of it evaporate right back into the air?
This is assuming that there is not enough water to turn the pump on.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-06-2010, 10:08 AM   #3
gmhammes's Avatar
is that the orginal drain on the bottom? Did you plug it with anything?
gmhammes is offline   Reply With Quote
Old 08-06-2010, 10:40 AM   #4
Xtreme DIY'r
I have one that drains into a basement sink = laundry area
Its an older model, so we don't use it as much
Eventually I want the one in the main basement to drain to the same sink
Old 08-06-2010, 12:08 PM   #5
bbo
next one I buy will have a pump in it to pump into a sink or floor drain when full.
bbo is offline   Reply With Quote
Old 08-06-2010, 01:55 PM   #6
Wire Chewer
I thought that too, but it's just plastic. In the instructions it says I can unscrew something to hook up a hose, but there is no such thing on mine. Probably for a different model. Technically I could drill a hole in that part that sticks out and put the unit right over the sump pit drain, but I rather have the flexibility of being able to move it around, or even go without it (closing the tap).
I just tested it now and it works great, no leak!
Eventually I'll make a hookup on the furnace condensate line and hook it up there.
Old 08-09-2010, 03:37 PM   #7
Wire Chewer
ok so that caulk is not that great, after a few days it started leaking. Going to have to try the red caulk and see how that goes.
Old 08-11-2010, 08:10 AM   #8
bbo
I would make sure it is silicone caulk. Better yet, get a small tube of aquarium silicone.
Old 08-11-2010, 05:20 PM   #9
Wire Chewer
Used corning 736 100% silicone rubber caulk, so far it's holding up. I used that same stuff to seal the cleanouts of my main stack after I had to open it, it seems to work pretty good.
The other stuff was more made for mild caulking for baseboards and stuff, so even though it was "bathroom grade" I don't think it was truly waterproof. It had turned blue over time in some spots.
Old 08-11-2010, 07:29 PM   #10
fresh "tap" water whenever you need a drink too...
johnnyboy is offline   Reply With Quote
Old 08-11-2010, 08:12 PM   #11
Wire Chewer
Haha yeah, actually technically that water should be rather fresh. If it was a dry period I could use it to water the lawn lol.
In fact, for those that live where water is harder to come by, this is probably a great way to get water, with a much bigger unit of course.
Old 08-11-2010, 08:20 PM   #12
Xtreme DIY'r
I empty mine into plants & some small trees by the road
2yr old Haier Dehumidifier stopped working KE2KB Appliances 0 04-09-2010 07:14 PM
Humidifier and dehumidifier on furnace loadie HVAC 2 12-07-2008 04:16 PM
Can I do this w/a dehumidifier? famdog Plumbing 7 10-31-2008 10:53 AM
dehumidifier INSTEAD of crawl space vents DangerMouse Building & Construction 29 07-29-2008 01:55 PM
One bucket or two buckets of SLC KUIPORNG Flooring 7 02-26-2007 01:28 PM
