-   -   No more emptying the dehumidifier bucket! (http://www.diychatroom.com/f47/no-more-emptying-dehumidifier-bucket-78046/)
Red Squirrel 08-05-2010 11:47 PM
1 Attachment(s)
So I decided to get creative, and added a tap on my dehumidifier bucket. I can now attach a hose to it, and let it drain in the sump pit. The silicone caulk is still drying but I can't wait to give this a test tomorrow.
If you wonder why I put it sideways, it's to compensate for the hose bend radius.
Proby 08-05-2010 11:57 PM
If you dump it into your sump pit, won't a lot of it evaporate right back into the air?
This is assuming that there is not enough water to turn the pump on.
gmhammes 08-06-2010 09:08 AM
is that the orginal drain on the bottom? Did you plug it with anything?
Scuba_Dave 08-06-2010 09:40 AM
I have one that drains into a basement sink = laundry area
Its an older model, so we don't use it as much
Eventually I want the one in the main basement to drain to the same sink
bbo 08-06-2010 11:08 AM
next one I buy will have a pump in it to pump into a sink or floor drain when full.
Red Squirrel 08-06-2010 12:55 PM
I thought that too, but it's just plastic. In the instructions it says I can unscrew something to hook up a hose, but there is no such thing on mine. Probably for a different model. Technically I could drill a hole in that part that sticks out and put the unit right over the sump pit drain, but I rather have the flexibility of being able to move it around, or even go without it (closing the tap).
I just tested it now and it works great, no leak!
Eventually I'll make a hookup on the furnace condensate line and hook it up there.
Red Squirrel 08-09-2010 02:37 PM
ok so that caulk is not that great, after a few days it started leaking. Going to have to try the red caulk and see how that goes.
bbo 08-11-2010 07:10 AM
I would make sure it is silicone caulk. Better yet, get a small tube of aquarium silicone.
Red Squirrel 08-11-2010 04:20 PM
Used corning 736 100% silicone rubber caulk, so far it's holding up. I used that same stuff to seal the cleanouts of my main stack after I had to open it, it seems to work pretty good.
The other stuff was more made for mild caulking for baseboards and stuff, so even though it was "bathroom grade" I don't think it was truly waterproof. It had turned blue over time in some spots.
johnnyboy 08-11-2010 06:29 PM
fresh "tap" water whenever you need a drink too...
Red Squirrel 08-11-2010 07:12 PM
Haha yeah, actually technically that water should be rather fresh. If it was a dry period I could use it to water the lawn lol.
In fact, for those that live where water is harder to come by, this is probably a great way to get water, with a much bigger unit of course.
Scuba_Dave 08-11-2010 07:20 PM
I empty mine into plants & some small trees by the road
