No Hot Water From Furnace - Appliances - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 09:27 PM   #1
no hot water from furnace
We can't seem to ever get hot water from our furnace, which is the only source of hot water we have.
mgerry is offline   Reply With Quote
Old 02-01-2012, 12:14 AM   #2
Too Short? Cut it Again!
Have you flushed it recently? If it is full of crud the safety systems may be shutting it off or there is so much gunk there is not enough water to heat.
There should be a valved that looks like a garden spicket on the bottom of the boiler. With the system off, open that (with a hose to a nearby drain) and let it flow until the water runs more or less clear. It may start out looking like crude oil!
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Water around my steam furnace Volsar HVAC 1 12-11-2007 06:40 PM
Water on bottom of furnace timkay2 General DIY Discussions 5 10-17-2007 08:27 AM
