Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-17-2012, 02:50 PM   #1
No hot water
New hot water heater installed, not getting hot water thru the faucets
raiderk is offline   Reply With Quote
Old 12-17-2012, 04:34 PM   #2
No hot water
turn the valves back on?
danpik is offline   Reply With Quote
Old 12-17-2012, 07:43 PM   #3
No hot water
Is anything coming out when you open the faucet?
Look on top of the tank to see if they hooked it up backwards. (cold into the hot side)
Did they turn the heater back on?
Old 12-17-2012, 10:54 PM   #4
Missouri Bound's Avatar
No hot water
I see that you are new here...welcome. But do you really think that the information you gave is enough for anyone to give you an answer? Or are you just coming here to make a statement?
Do you want it your way or the right way?
Old 12-20-2012, 07:55 PM   #5
justinramani's Avatar
No hot water
Is it electric? Maybe they turned on power without filling the entire tank and burned out one (or both) of the elements.
justinramani is offline   Reply With Quote
Old 12-20-2012, 10:09 PM   #6
No hot water
perhaps he has figured a solution to his problem...
oodssoo is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
