Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-18-2012, 10:21 AM   #1
NO heat and NO hot water
Woke up with no heat and no hot water. I have a forced water radiator system. Furnace is only 1 year old. water heater is about 8. the pilot is still lit on the waterheater. the gas dryer is still working fine.
I'm a bit confused, it was my understanding that the furnace heated its own water.
Any ideas??
zoiberg137 is offline   Reply With Quote
Old 01-18-2012, 12:31 PM   #2
MarginallyQualified
furnace ? or boiler? I'll assume boiler with DHW coil.
Call the company that installed it one year ago...
they'll ask you some simple yes/no questions based in them knowing how it was set up.
Depending on how that goes... they'll maybe need to send out a mechanic.
If one does come out... be sure you get taught what to look for next time.
Hot water Heat repairs and our warranty Salvatorparadise General Discussion 16 01-31-2011 12:35 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Need help with heat and hot water issue Spydey HVAC 50 03-07-2010 09:46 PM
water dripping from heat vents pamleo HVAC 8 01-28-2009 10:40 PM
