No Ground Wire For Dishwasher - Appliances - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 04:06 PM   #1
No Ground Wire for Dishwasher
Hello,
We have had a TON of irritating issues in installing a new dishwasher. The final one? There is no ground wire, just the one red and one white wire coming from the wall.
When our old one first had trouble, our appliance repair guy said it wasn't grounded properly, and did something to the wiring which he said would fix it. What could he have done? He did not run a new wire from the dishwasher to the box that can be accessed from the basement.
Is there some easier way to ground it that does not include running a wire all the way from the box to the dishwasher?
Is it horrific to use it without it being grounded?
Finally, if we have to add a ground wire, what parts do you need and what do you do?
Thanks so much in advance for your help! This whole dishwasher experience has been a nightmare and I just can't wait for it to be over.
Kristin12 is offline   Reply With Quote
Old 01-09-2010, 05:25 PM   #2
Civil Engineer
Rewards Points: 4,690
It is a good idea to put the dishwashwasher on its own circuit. Based on the fact that the hot wire is apparently red, I wonder if your dishwasher circuit is shared with at least one other device. Also, the dishwasher typically has a green grounding screw on the dishwasher. This screw is intended to be used to attach the green or bare copper equipment ground wire that should be part of the circuit (typically there would be a black hot, a white neutral, and a green or bare ground wire).
From your description, it sounds like there is no ground wire in the circuit. I wonder if the ground was cut off?
The best solution would be to run a new, 20A, 12 gage circuit from the panel to the dishwasher. Where I live, you are also supposed to have a positive means of disconnecting the dishwasher that is visible from the dishwasher. Typically this means installing a switch above the counter that is wired ahead of the dishwasher on the circuit. I don't think this is even NEC code, just a local requirement, but you may have something similar. Good to check with the code enforcement officer before you install the circuit.
Old 01-09-2010, 05:46 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is the junction box in the wall metal or plastic?
Do you know why NM (Romex) cable is?
BX cable?
If so, do you have any idea what type of cable is present in this circuit?
are you comfortable with opening up your electrical panel? If so, remove the front and look at the cable coming in from the dishwasher to see if there is a ground wire in that cable.
Old 01-18-2010, 10:10 PM   #4
Rewards Points: 530
I am assuming this is older wiring? I am also thinking maybe the other guy jumped a wire from the neutral to the ground on the recepticle.
The red wire for hot feed is confusing to me for a 110 circuit.
no ground wire jamesm113 Electrical 9 08-30-2009 08:40 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
