No Cold Air In Roper Refrigerator - Appliances - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 07:28 PM   #1
No Cold air in Roper Refrigerator
I have a 2002 roper refrigerator (not sure on the model) and the bottom part (fridge) is not getting cold. The freezer is plenty cold, but there is no air coming out of the vents in the bottom half. I have done the following:
1. Turned off entire unit for about 12 hours to see if there was any frozen condensate in the vents...no hint of any air movement when I plugged back in
2. removed rear panel in freezer - coils were frost free and fan was working. Drain was not clogged as I could see clear drainage into the drain pan as I was working.
3. Just for kicks I ran a defrost cycle. It kicked on as it should have (but there was no frost/ice on the coils so it didn't really matter).
Anyone have any thoughts on this?
Thanks!
sobro is offline   Reply With Quote
Old 06-21-2013, 08:08 AM   #2
Rewards Points: 13,300
Really need that model #.
http://www.repairclinic.com/RepairHe...ot-cold-enough
Old 06-21-2013, 11:01 AM   #3
Yeah - that was a fail on my part. With all things considered, is there a motor/linkage that moves the baffles for cold air to flow down into the refrigerator part.
Or, is that something that is also dependent upon model #?
Either way, I'll try and have a look tonight and post it.
Old 06-21-2013, 11:50 AM   #4
Rewards Points: 254
you will have a freezer fan but also one going to the fridge if its like my old Roper
pwgsx is offline   Reply With Quote
Old 06-21-2013, 01:15 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
the air flow into the refrig is controlled by the little damper you turn to adjust the freezer temp. Try turning your freezer temp to off and see what you get
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Tags
no cold air , refrigerator , roper
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 12:24 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Refrigerator or Freezer not Cooling or Getting Cold movd62 Appliances 0 03-17-2012 02:34 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Refrigerator not cold but freezer is thehvacguy HVAC 8 11-09-2009 07:47 PM
