Newer GE Top Loader Washer Buzzes When Should Shut Off - Appliances - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 09:48 AM   #1
Rewards Points: 562
Newer GE top loader washer buzzes when should shut off
I have a new near new top loading GE clothes washer that is used little for a 1 person house. When it should be done and shut itself off it just sits there and buzzes. NOT a done warning buzz,,,but like something is stuck. It will buzz for days or weeks till shut off manually. It washes fine,it spins water out when done,,,what can possibly buzz like that?? Obviously something needs fixed but where to start???
4just1don is offline   Reply With Quote
Old 08-04-2011, 10:21 AM   #2
fabrk8r
fabrk8r's Avatar
This is what I would do. Whether you feel comfortable doing it is another matter.
1. Turn off all power to the unit (unplug cord) and remove enclosure. The enclosures on most washing machines are fairly easy to remove. It will help if you have an "owners manual" with a parts diagram.
2. Make sure everything is clear from any moving parts and electrical components.
3. Make double sure everything is clear from any moving parts and electrical components.
4. Reapply power to the machine and look (don't touch!) and listen for the part that is buzzing.
5. When you find the part that is making the offending noise, disconnect the power again before working on the unit.
BTW, Google is your friend when it comes to finding instructions on appliance repair. Enter the model number and a couple words describing the problem concisely.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-04-2011, 11:21 AM   #3
Rewards Points: 562
thanks will try that when I get a minute. update a bit--it is filling, wasings, and spinning firt fill as should. When its time for rinse to fill again is when buzz occurs. that doesnt make sense to me if it doesnt fill why does it fill on wash cycle??
Old 08-04-2011, 11:25 AM   #4
Rewards Points: 150
If it is wasing and spinning firt then it is worse than we thought!
Broughton is offline   Reply With Quote
Old 08-04-2011, 11:54 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
can not respond to mumbo jumbo.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Front loader washer transport bolts Richo Appliances 2 11-03-2010 12:59 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
New Front Loader Washer and Dryer thekoaman Plumbing 1 08-28-2010 07:14 PM
Trying to shut off water to install washer and dryer husband&me Plumbing 4 04-04-2010 10:34 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
