Originally Posted by DannyT
how long have you had the pilot depressed?. if the gas line was taken apart it has air in it that needs to be purged before it will light. sometimes you just need to hold the pilot depressed for a longer time. did you try lighting the pilot with a grill lighter to see if there IS enough gas at the pilot?
Well per instructions ive held down the gas button at the most 90 seconds while I click on the igniter.. I'm afraid to do more than 90 seconds since I dont want the thing to blow up and ruin my pretty face..
I've done this about 5 times now and the status light won't come on at all..
There is gas coming through because I hear it and I kinda loosen up the gas line and was able to smell a it.. Plus my water heater and furnace kind of share the same gas line and my furnace fires up fine.. I was thinking of lighting it with the torch light but per instruction it said not to try it.. I've never messed with a water heater before.. 5 days ago I didn't know squat about them.. I mostly work on cars but have never messed around home appliances...
