New Range Hood Question - Appliances - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 11:31 AM   #1
Newbie Bill
Rewards Points: 520
New range hood question
Hey Gang,
We are going to install a new range hood in our kitchen. The ones we are looking at are about 600 cfm. It is likely more cfms that we need.
However, I have been told we don't want to rob our furnace of combustible air.
We have a high efficiency furnace. I thought most of the combustible air is brought in from the outside.
Do we still need to be concerned with this?
Should I just contact our local HVAC gurus?
Thanks,
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-25-2009, 07:08 PM   #2
Post this on the HVAC section. 3 or 4 pros there daily
Chemist1961 is offline   Reply With Quote
Old 05-25-2009, 08:10 PM   #3
Newbie Bill
Rewards Points: 520
Will do Chemist.
Thanks.
Bill
Old 05-25-2009, 08:15 PM   #4
Not really sure what a hood has to do with a furnace, honestly. I've been in the construction business for some time and have never heard of a kitchen hood having any relation to a furnace.
Could you explain a little more in depth?
jordy3738 is offline   Reply With Quote
Old 05-26-2009, 09:05 AM   #5
Newbie Bill
Rewards Points: 520
Jordy,
I am concerned that the range hood can pull enough air out of the home and take combustible air away from the furnace and/or hot water heater.
I don't know exactly what can occurs when that happens, but I think it leads to higher levels of carbon monoxide in the home.
Bill
Old 05-26-2009, 09:56 AM   #6
This response is totally from a common sense approach so please do note put a lot of confidence in my view. I am a native Floridian not a Northerner.
It seems as though a range hood only gets used about a half hour at a time unless you have a really large family, if that's the case you should be living in a home large enough to maintain the proper air levels.
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
suggestions on contructing a range hood steve1234 Carpentry 15 08-30-2010 10:35 PM
Range hood wiring question, help!! nyc_apt_dweller Electrical 4 03-05-2009 08:34 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 04:43 PM
