Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-20-2011, 01:59 PM   #1
new hot water heater,lowered hot water pressure
i installed a new Richmond gas hot water heater, afterwards, my hot water pressure is much lower than the cold water,whats up with that?
fuzzhoff@hotmai is offline   Reply With Quote
Old 11-20-2011, 02:04 PM   #2
Tileguy
Bud Cline's Avatar
whats up with that?
Don't know! What did you do different? New valves? Pipe downsize to save money? Partially closed valve? Loosened debris inside pipe?
Old 11-21-2011, 08:40 AM   #3
Milwaukeetool's Avatar
how old are your water pipes? old metal ones? I,ve seen them so built up with crud that I couldn't fit a pencil in the pipe. If this is the case new water piping is needed.
Milwaukeetool is offline   Reply With Quote
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
what is the thing called that stores water under pressure for low water pressure? oregongirl23 Plumbing 18 08-08-2010 03:09 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
