Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-24-2009, 08:52 PM   #1
Default New Dishwasher Water Line Leaking HELP!
I'm trying to install a new dishwasher today but the water line is leaking where it meets the 90 degree elbow adapter. I originaly didn't have the elbow adapter but I did have a the old water line. I went to sears today and bought the whole kit which includes the line and adapter. With the old water line it leaks. All the instructions I have read say don't over tighten. I've tightened it as far as it will go with a wrench and I litteraly can not tighten it any further. So I tried the new water line that came with the kit and I have the same exact problem. What am I doing wrong? Please help.
benchmarkman is offline   Reply With Quote
Old 10-26-2009, 08:44 AM   #2
Assuming you have the compression washer in place the only thing I can suggest is to put a little lubricant on the threads, line and compression washer. Lithium grease works best, pipe dope or Teflon is good and Vaseline or even vegetable oil will work in a pinch.
Rege
RegeSullivan is offline   Reply With Quote
Old 11-04-2009, 03:19 AM   #3
Hi all!
I've just visited this forum. Happy to get acquainted with you. Thanks.
________________
Free Anime Episodes
hcm2009 is offline   Reply With Quote
More On This Topic
Whether you're remodeling a kitchen or you have a broken dishwasher, installing a new one can be fairly easy and completed in less than one day. A new dishwasher has been known to make hectic lives easier, because you can start it and leave it to do its... Read More »
If you smell a gas leak, it’s imperative that you locate the gas leak and shut off the gas and have it repaired. And it’s very easy to locate the source of a gas leak. Just use some dishwashing liquid and some water - about a half and half... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and we’re installing a new dishwasher. The water inlet, which is, everything’s located on the bottom. You just want to take some Teflon tape and... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and today we are replacing the hot water pipe and valve. Now we’ve already installed the valve, which is a two outlet valve- one for the sink and one for... Read More »
You don't want to over tighten it. You want to give it a water test, see if any water is going to be leaking out of the side. Once you put it on, you want to basically look right here to see if any water is coming out of here. As of right now it's dried... Read More »
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 11:51 AM
Water leaking out left side vent(?) of Dishwasher Barkley Online Appliances 6 07-21-2009 08:36 AM
Blockage in kitchen water line. Local Yokel Plumbing 6 03-19-2009 12:34 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 01:41 PM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 10:51 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
