-   -   New Dishwasher Water Line Leaking HELP! (http://www.diychatroom.com/f47/new-dishwasher-water-line-leaking-help-55854/)
benchmarkman 10-24-2009 06:52 PM
I'm trying to install a new dishwasher today but the water line is leaking where it meets the 90 degree elbow adapter. I originaly didn't have the elbow adapter but I did have a the old water line. I went to sears today and bought the whole kit which includes the line and adapter. With the old water line it leaks. All the instructions I have read say don't over tighten. I've tightened it as far as it will go with a wrench and I litteraly can not tighten it any further. So I tried the new water line that came with the kit and I have the same exact problem. What am I doing wrong? Please help.
RegeSullivan 10-26-2009 06:44 AM
Assuming you have the compression washer in place the only thing I can suggest is to put a little lubricant on the threads, line and compression washer. Lithium grease works best, pipe dope or Teflon is good and Vaseline or even vegetable oil will work in a pinch.
Rege
hcm2009 11-04-2009 01:19 AM
Hi all!
I've just visited this forum. Happy to get acquainted with you. Thanks.
________________
Free Anime Episodes
firehawkmph 12-12-2009 10:37 AM
Benchmark,
Anymore I have been using the stainless steel braided water supply lines. I don't care for the plastic tubing and compression fittings. Just my preference. The braided lines are pretty much foolproof and very easy to install. They use a rubber washer in each end instead of a copression nut. They come in a 5' length for dishwasher hookups.
Mike Hawkins:)
Thurman 12-13-2009 08:45 AM
IF your are using the plastic line, which I don't care for either, are you using the "sleeve" which goes into the end of the line? These prevent the ferrule from squeezing the plastic line too much which will cause a leak, and should have been in the new kit. If you are using the copper line, the sleeve is not necessary. Good Luck, David
