New Bosch Dishwasher Not Cleaning Dishes - Appliances - DIY Chatroom Home Improvement Forum
Old 07-29-2015, 06:52 AM   #1
Rewards Points: 68
New Bosch Dishwasher not cleaning dishes
Purchased a New Bosch Dishwasher, Model SHE3ARF2UC and had it installed by my handyman. Water is going through unit when door is opened during a cycle. Dishwashing tabs are not dissolving and will be broken up after a cycle is run but dishes will still have food on them and cups will not be clean. Not sure what do as we thought Bosch was the highest rated dishwashers on the market. Our 16 year-old GE worked fine in cleaning dishes but felt we needed a new one as we were afraid of a break down. Please advise.
jnstevens is offline   Reply With Quote
Old 07-29-2015, 07:06 AM   #2
Rewards Points: 42
Check your manual. Some dishwashers require the use of powdered detergent.
Dan
djlandkpl is offline   Reply With Quote
Old 07-29-2015, 07:10 AM   #3
Rewards Points: 68
I am using the "Finish All-in-one " dishwasher tab samples that came with the new unit. The manual and on the dishwasher door it says to use the Finish products.
Old 07-29-2015, 07:46 AM   #4
Rewards Points: 42
I looked up the manual. On page 10 it says for best results use fresh powdered dish washing detergent.
If you have hard water, you'll likely need to use a rinse agent too. I have a family member with a similar Bosch with hard water. The cleaning results weren't great until she started using the rinse agent.
Dan
Old 07-29-2015, 07:52 AM   #5
Rewards Points: 68
I have put the "Finish" rinsing agent in the rinse aid dispenser. I can get some powdered dish washing detergent and try that. Do you think my hot water heater isn't set high enough for the new dishwasher?
Old 07-29-2015, 08:07 AM   #6
The dishwasher detergent recommendation is basically paid advertising by the detergent company . I find in my kitchen aide that powder detergent using the two soap cups work best. If I use a detergent pod in mine, it goes in the soap dish with door . Liquids do an awful job in my dishwasher. Make sure you are putting the pod in the correct location per your owners manual.
As for water, most upper end dishwashers heat the water internally to get it up to the correct temp.
jimn01 is offline   Reply With Quote
Old 07-30-2015, 06:36 AM   #7
Rewards Points: 68
I've tried Heavy, Auto, and Normal settings and the tabs would not dissolve and dishes are still dirty. Last night I bought some power dishwasher cleaner and it worked ok. There was some powder residue and the dishes were cleaner but seems like the dishes should be cleaner. ???
Old 07-30-2015, 07:32 AM   #8
Rewards Points: 42
Toss the tabs. They aren't going to work. Use less powder and that should stop the residue. Try a level tablespoon. Newer dishwashers use a lot less water than older models.
Dan
Old 07-30-2015, 09:58 AM   #9
Rewards Points: 83
I think you're missing the point. Op is still having an issue with dishes being dirty. This is likely not an issue of using packs but rather not enough cleaning going on.
I would check to ensure that you have enough water pressure going to the dishwasher. I would also ensure the supply is fully open. I do not know what your model does but some dishwashers just work off a timed fill cycle and not a water level per se.
I would also ensure that the sump of the motor is clear. There is usually a tray to catch this stuff. I would clean it to ensure that there isn't any plastic or anything put in by the manufacturer.
I would also run down the install manual and reread it to ensure all installation procedures were met. Sometimes the smallest detail can cause issues(unit not being level, incorrect supply pressure)
Finally after all that is done, it may need to have to be looked at. Sometimes it takes a trained set of eyes to see the non-obvious.
Protocol. is offline   Reply With Quote
Old 07-30-2015, 10:27 AM   #10
Rewards Points: 42
Post #7 tells me there's too much detergent. I'm relaying personal experience with a Bosch. Same issues. Hard water and a combination of to much detergent left residue which makes the dishes look dirty, especially glassware.
Dan
Old 07-30-2015, 10:36 AM   #11
Rewards Points: 5,336
Try a liquid detergent.
Ron
B. Franklin 1759
Old 07-31-2015, 08:06 AM   #12
Rewards Points: 68
Pretty sure the water valve is on all the way. I put a tbl. spoon of powder and that didn't even dissolve all the way. Water is hot but not real full by the drain plug, just to the filter. I guess since the d/w is under the Bosch warranty I will call an appliance company in my area to come out and check things out. Very frustrating!
Old 07-31-2015, 11:23 AM   #13
Rewards Points: 1,668
What is the actual temp of the hot water coming out of the tap? Are you using a thermometer? 120 degrees is pretty hot on the hand; you may be misjudging the temp.
bob22 is offline   Reply With Quote
Old 07-31-2015, 11:38 AM   #14
Rewards Points: 68
There is definitely not enough water coming in. There's not even enough water to make it to the float switch. (the round thing in the photo behind your spray arm )
If your water valve is fully open, you most likely have a pinched water line or because the installer did not flush the water line before hooking it up to the new d/w you now have a clogged water valve screen..
This is an installer issue and they should take care of it for you. Most manufacturers will not cover by warranty an installation issue. This is what I have been told. Sound about right?
Old 07-31-2015, 12:35 PM   #15
I would assume that the float turns the water off so if the line was being pinched some, it might slow down the fill rate, but would not stop it from being filled. I'd call Bosch and tell them to send a repair person since it isn't working right. Bosch machines aren't cheap.
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
White residue from my dishwasher on my dishes. Chris Woodruff Appliances 1 10-31-2011 07:21 AM
Bosch Dishwasher shu9915 problems daveinpa Appliances 0 05-13-2011 07:43 PM
bosch dishwasher shu9915 not cleaning properly daveinpa Electrical 0 05-13-2011 04:45 PM
Bosch Dishwasher - No Insulation?? NateHanson Appliances 2 12-16-2009 05:46 AM
