Neptune Front Load Washer Leaking Water - Appliances - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 07:48 AM   #1
Neptune Front Load Washer leaking water
My washer is leaking water heavily from the front door (over filling). Model Number MAH6500AWW. I had to turn off the water and wet vac out the water. Is this a switch problem?
rickmartindale is offline   Reply With Quote
Old 05-16-2013, 09:22 AM   #2
Rewards Points: 13,468
That model # comes up as a top loader.
Old 05-16-2013, 09:55 AM   #3
Right Model number for front loader
Maytag MAH6500AWW 27" Front-Load Washer with 3.34 Cu
Old 05-16-2013, 09:57 AM   #4
This is a front loader.
Old 05-16-2013, 02:26 PM   #5
Rewards Points: 744
It's a front-loader http://www.repairclinic.com/RepairHe...roubleshooting
Rick, that link would be a good place to start.
Seattle2k is offline   Reply With Quote
Old 05-16-2013, 07:40 PM   #6
Rewards Points: 83
Most likely clogged water pressure switch line. Crap builds up on the drum + blocks off the line.
Could also be failed pressure switch or failed water inlet valve.
Protocol. is offline   Reply With Quote
Old 05-16-2013, 09:27 PM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
on top of the pump is the water level switch, remove it and check for gunk build up blocking the little pressure hole. FYI, it may be easier for you to remove the pump and switch as an assembly
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Main hot water pipe leaking under slab tiredofleaks Plumbing 9 09-12-2011 02:45 PM
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 08:29 PM
Whirlpool Duet washer front load sdaniels Appliances 3 03-13-2011 03:37 PM
front load washer flooring choices algored2deth Flooring 0 02-28-2011 12:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
