Need Some Help - Appliances - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 06:02 PM   #1
Need some help
Hey all. I am new here and am having some trouble. I have a hotpoint model hda460-03 ad. Yes I know it is super old. I am having trouble getting the proper pressure to clean dishes. It won't even dissolve the detergent packet. I am at a loss. Please help.
jamesrw30 is offline   Reply With Quote
Old 05-31-2012, 07:08 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
check water level, check pump filter
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-31-2012, 08:39 PM   #3
Thumbs down
How do I go about checking level? I am super new to this. I know I can't run it until the door is closed and latched. Sorry for sounding stupid.
Old 05-31-2012, 08:57 PM   #4
Rewards Points: 83
Give the wash arms a good clean.
Pull them out and give them a good clean. there is usually a build up in the arms. Also typically see a build up in the sump area. Could also be the motor pump impeller worn out.
Protocol. is offline   Reply With Quote
Old 05-31-2012, 09:22 PM   #5
I will look into that. Hopefully the motor isn't wearing out, I imagine as old as this one is it would cost as much to fix as replace the whole thing.
Old 05-31-2012, 11:21 PM   #6
#1 HAWKEYE FAN
check water level first. Let dishwasher fill, when it starts to wash open door water should be almost touching the heating element
Old 06-01-2012, 07:49 AM   #7
Thank you. I will check that.
