Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-28-2012, 10:16 AM   #1
drs
Need to know the circuit breaker requirement
Got a new stove and the label is this:
120/240V , 60Hz: 11.9kw
120/208V , 60hZ: 8.9kw
ac only 60Hz
Trying to determine the required circuit breaker size
thanks
drs is offline   Reply With Quote
Old 08-28-2012, 01:07 PM   #2
Amps X volts = watts
I get 50A @240V
danpik is offline   Reply With Quote
Old 08-29-2012, 12:07 AM   #3
Bombastic Idiot
notmrjohn's Avatar
Check the manual that came with the stove. It should also tell you what gauge wire to use.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 08-29-2012, 10:48 PM   #4
49.58 amps @ 240V is what I get. Is this for the entire unit? It sounds about right for a typical 240V stove.
Protocol. is offline   Reply With Quote
Backfeed Circuit Breaker Knucklehead_BW Electrical 13 01-11-2012 10:17 PM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 10:45 PM
circuit breaker? blueandyellow Electrical 7 01-30-2011 11:27 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
