-   -   Need to know the circuit breaker requirement (http://www.diychatroom.com/f47/need-know-circuit-breaker-requirement-155091/)
drs 08-28-2012 10:16 AM
Got a new stove and the label is this:
120/240V , 60Hz: 11.9kw
120/208V , 60hZ: 8.9kw
ac only 60Hz
Trying to determine the required circuit breaker size
thanks
danpik 08-28-2012 01:07 PM
Amps X volts = watts
I get 50A @240V
notmrjohn 08-29-2012 12:07 AM
Check the manual that came with the stove. It should also tell you what gauge wire to use.
Protocol. 08-29-2012 10:48 PM
49.58 amps @ 240V is what I get. Is this for the entire unit? It sounds about right for a typical 240V stove.
